[GRASS-QA] GRASS QA: mmetz |net.c | no clones | 2 monsters |2 warnings
soccerlab.info at gmail.com
Sun Feb 13 05:22:12 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45392
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/Vlib/net.c
Function
Vect_net_shortest_path_coor(Begins at: 862, Ends at:873)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 16 | *** | MONSTER | 16 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 12 | | OK | 12 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Vect_net_shortest_path_coor2(Begins at: 894, Ends at:1156)
Complexity: | 46 | *** | MONSTER | 46 |
ParamNBR: | 17 | *** | MONSTER | 17 |
CalledNBR: | 56 | ** | BABY-MONSTER | 56 |
LOC: | 263 | *** | MONSTER | 263 |
Vect_net_get_line_cost(Begins at: 558, Ends at:603)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 46 | | OK | 46 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_net_shortest_path(Begins at: 457, Ends at:544)
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 88 | * | WARNING | 88 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sun Feb 13 05:22:09 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
