[GRASS-QA] GRASS QA: mmetz |main.c global.h function.c | 13 clones | 2 monsters |12 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Feb 13 05:26:23 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45393
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.kernel/main.c
          Function
count_node_arcs(Begins at: 676, Ends at:689)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
compute_distance(Begins at: 791, Ends at:840)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      50 |       |           OK |        50 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
main(Begins at: 73, Ends at:530)
Complexity:   |      48 |   *** |      MONSTER |        48 |
CalledNBR:    |     155 |   *** |      MONSTER |       155 |
LOC:          |     458 |   *** |      MONSTER |       458 |
Conclusion:   | this function is a       MONSTER           |
L(Begins at: 38, Ends at:70)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
compute_net_distance(Begins at: 692, Ends at:789)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      98 |     * |      WARNING |        98 |
compute_all_net_distances(Begins at: 599, Ends at:673)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      75 |     * |      WARNING |        75 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/main.c clones of compute_all_net_distances are:
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/main.c  compute_all_net_distances
          File :/vector/v.kernel/global.h
The system don't find class, method and function
 in this file during analysis!
          File :/vector/v.kernel/function.c
          Function
quarticKernel(Begins at: 166, Ends at:181)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      16 |       |           OK |        16 |
 at least 1 values are close to an outlier please consider revising code!
triangularKernel(Begins at: 132, Ends at:147)
CalledNBR:    |       1 |       |           OK |         1 |
kernelFunction(Begins at: 217, Ends at:246)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      30 |       |           OK |        30 |
 at least 2 values are close to an outlier please consider revising code!
epanechnikovKernel(Begins at: 149, Ends at:164)
euclidean_distance(Begins at: 87, Ends at:99)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      13 |       |           OK |        13 |
uniformKernel(Begins at: 115, Ends at:130)
cosineKernel(Begins at: 200, Ends at:215)
invGaussian2d(Begins at: 76, Ends at:83)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
triweightKernel(Begins at: 183, Ends at:198)
gaussianKernel2(Begins at: 103, Ends at:111)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
kernel1(Begins at: 58, Ends at:73)
gaussian2dBySigma(Begins at: 9, Ends at:17)
metrics are OK
Clone analysis:
This file has 12 potentially cloned functions:
  cosineKernel  uniformKernel  epanechnikovKernel  uniformKernel  triangularKernel  triangularKernel  epanechnikovKernel  quarticKernel  triweightKernel  quarticKernel  cosineKernel
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c clones of quarticKernel are:
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c  triweightKernel
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c  cosineKernel
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c clones of triangularKernel are:
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c  uniformKernel
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c  epanechnikovKernel
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c clones of epanechnikovKernel are:
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c  triangularKernel
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c clones of uniformKernel are:
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c clones of cosineKernel are:
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c  quarticKernel
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.kernel/function.c clones of triweightKernel are:
____________________________________________
Threshold grass key metrics values at Sun Feb 13 05:26:21 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
