[GRASS-QA] GRASS QA: mmetz |plus_area.c | no clones | 0 monsters |2
warnings
soccerlab.info at gmail.com
Tue Jan 4 05:01:44 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44854
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/diglib/plus_area.c
Function
dig_angle_next_line(Begins at: 477, Ends at:566)
| New Metrics |Old Metrics|
Complexity: | 17 | * | WARNING | 17 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 90 | * | WARNING | 90 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
dig_build_area_with_line(Begins at: 51, Ends at:160)
Complexity: | 18 | * | WARNING | 18 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 110 | * | WARNING | 110 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jan 04 05:01:41 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
