[GRASS-QA] GRASS QA: mmetz |split.c indexf.c rtree.h gammavol.c ...| no clones | 0 monsters |42 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jan 4 05:05:30 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44855
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/rtree/split.c
          Function
RTreeInitPVars(Begins at: 161, Ends at:174)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
RTreeMethodOne(Begins at: 453, Ends at:586)
Complexity:   |      18 |     * |      WARNING |        18 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |     134 |     * |      WARNING |       134 |
 at least 3 values are close to an outlier please consider revising code!
RTreePartitionBranchBuf(Begins at: 346, Ends at:404)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      59 |       |           OK |        59 |
 at least 2 values are close to an outlier please consider revising code!
RTreeLoadNodes(Begins at: 144, Ends at:156)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
RTreePrintPVars(Begins at: 180, Ends at:213)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      34 |       |           OK |        34 |
Conclusion:   | this function is a            OK           |
metrics are OK
RTreeClassify(Begins at: 82, Ends at:99)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      18 |       |           OK |        18 |
RTreeMethodZero(Begins at: 229, Ends at:290)
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      62 |       |           OK |        62 |
RTreeGetBranches(Begins at: 42, Ends at:77)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      36 |       |           OK |        36 |
RTreeSplitNode(Begins at: 594, Ends at:619)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      26 |       |           OK |        26 |
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/rtree/indexf.c
          Class
fstack(Begins at: 30, Ends at:35)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Function
RTreeDeleteRect2F(Begins at: 314, Ends at:409)
Complexity:   |      13 |     * |      WARNING |        13 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      96 |     * |      WARNING |        96 |
 at least 4 values are close to an outlier please consider revising code!
RTreeDeleteRectF(Begins at: 419, Ends at:471)
LOC:          |      53 |       |           OK |        53 |
RTreeInsertRect2F(Begins at: 117, Ends at:222)
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |     106 |     * |      WARNING |       106 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
RTreeInsertRectF(Begins at: 232, Ends at:306)
LOC:          |      75 |     * |      WARNING |        75 |
RTreeSearchF(Begins at: 47, Ends at:106)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      60 |       |           OK |        60 |
RTreeValidChildF(Begins at: 37, Ends at:40)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/rtree.h
The system don't find class, method and function
 in this file during analysis!
          File :/lib/vector/rtree/gammavol.c
          Function
main(Begins at: 36, Ends at:48)
ParamNBR:     |       0 |       |           OK |         0 |
metrics are OK
sphere_volume(Begins at: 27, Ends at:34)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/rect.c
          Function
RTreeCombineRect(Begins at: 322, Ends at:341)
LOC:          |      20 |       |           OK |        20 |
RTreeCompareRect(Begins at: 347, Ends at:361)
LOC:          |      15 |       |           OK |        15 |
RTreeContained(Begins at: 387, Ends at:408)
LOC:          |      22 |       |           OK |        22 |
RTreeInitRect(Begins at: 38, Ends at:45)
metrics are OK
RTreeNullRect(Begins at: 52, Ends at:62)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
RTreeOverlap(Begins at: 367, Ends at:381)
RTreePrintRect(Begins at: 130, Ends at:143)
ParamNBR:     |       2 |       |           OK |         2 |
metrics are OK
RTreeRectMargin(Begins at: 304, Ends at:316)
metrics are OK
RTreeRectSphericalVolume(Begins at: 254, Ends at:269)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
RTreeRectSurfaceArea(Begins at: 275, Ends at:297)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
RTreeRectVolume(Begins at: 148, Ends at:162)
metrics are OK
sphere_volume(Begins at: 178, Ends at:185)
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/index.c
          Function
RTreeDeleteRect(Begins at: 174, Ends at:183)
LOC:          |      10 |       |           OK |        10 |
RTreeFreeIndex(Begins at: 117, Ends at:129)
metrics are OK
RTreeFreeListBranch(Begins at: 215, Ends at:218)
metrics are OK
RTreeFreeListNode(Begins at: 194, Ends at:197)
metrics are OK
RTreeInsertRect(Begins at: 150, Ends at:160)
RTreeNewIndex(Begins at: 34, Ends at:115)
LOC:          |      82 |     * |      WARNING |        82 |
RTreeNewListNode(Begins at: 189, Ends at:192)
metrics are OK
RTreeReInsertNode(Begins at: 203, Ends at:210)
metrics are OK
RTreeSearch(Begins at: 136, Ends at:142)
LOC:          |       7 |       |           OK |         7 |
Clone analysis:
          File :/lib/vector/rtree/node.c
          Class
dist(Begins at: 27, Ends at:31)
          Function
RTreeAddBranch(Begins at: 498, Ends at:548)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
LOC:          |      51 |       |           OK |        51 |
RTreeDestroyNode(Begins at: 252, Ends at:266)
metrics are OK
RTreeDisconnectBranch(Begins at: 231, Ends at:248)
RTreeDistIsSorted(Begins at: 289, Ends at:299)
RTreeFreeNode(Begins at: 82, Ends at:86)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
RTreeInitLeafBranch(Begins at: 48, Ends at:52)
metrics are OK
RTreeInitNode(Begins at: 60, Ends at:69)
metrics are OK
RTreeInitNodeBranchF(Begins at: 41, Ends at:45)
metrics are OK
RTreeInitNodeBranchM(Begins at: 34, Ends at:38)
metrics are OK
RTreeNewListBranch(Begins at: 399, Ends at:402)
metrics are OK
RTreeNewNode(Begins at: 72, Ends at:80)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
RTreeNodeCover(Begins at: 92, Ends at:123)
Complexity:   |       8 |       |           OK |         8 |
LOC:          |      32 |       |           OK |        32 |
metrics are OK
RTreePartitionDist(Begins at: 304, Ends at:357)
LOC:          |      54 |       |           OK |        54 |
RTreePickBranch(Begins at: 196, Ends at:228)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      33 |       |           OK |        33 |
RTreePickLeafBranch(Begins at: 137, Ends at:187)
Complexity:   |       9 |     * |      WARNING |         9 |
RTreePrintBranch(Begins at: 562, Ends at:566)
RTreePrintNode(Begins at: 569, Ends at:599)
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      31 |       |           OK |        31 |
RTreeQuicksortDist(Begins at: 363, Ends at:393)
metrics are OK
RTreeReInsertBranch(Begins at: 408, Ends at:418)
RTreeRemoveBranches(Begins at: 425, Ends at:489)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      65 |       |           OK |        65 |
RTreeSwapDist(Begins at: 277, Ends at:284)
metrics are OK
RTreeTabIn(Begins at: 554, Ends at:560)
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/indexm.c
          Class
stack(Begins at: 26, Ends at:30)
          Function
RTreeDeleteRect2M(Begins at: 281, Ends at:361)
Complexity:   |      12 |     * |      WARNING |        12 |
LOC:          |      81 |     * |      WARNING |        81 |
RTreeDeleteRectM(Begins at: 371, Ends at:424)
RTreeInsertRect2M(Begins at: 109, Ends at:193)
LOC:          |      85 |     * |      WARNING |        85 |
RTreeInsertRectM(Begins at: 203, Ends at:273)
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      71 |     * |      WARNING |        71 |
RTreeSearchM(Begins at: 42, Ends at:98)
LOC:          |      57 |       |           OK |        57 |
RTreeValidChildM(Begins at: 32, Ends at:35)
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/split.h
          Class
PartitionVars(Begins at: 27, Ends at:34)
Clone analysis:
          File :/lib/vector/rtree/index.h
          Class
Branch(Begins at: 72, Ends at:76)
          Class
Child(Begins at: 65, Ends at:70)
          Class
ListBranch(Begins at: 166, Ends at:171)
          Class
ListFNode(Begins at: 160, Ends at:164)
          Class
ListNode(Begins at: 154, Ends at:158)
          Class
Node(Begins at: 78, Ends at:83)
          Class
NodeBuffer(Begins at: 135, Ends at:140)
          Class
RTree(Begins at: 102, Ends at:152)
          Class
Rect(Begins at: 58, Ends at:61)
          Class
_recycle(Begins at: 126, Ends at:130)
Clone analysis:
          File :/lib/vector/rtree/io.c
          Function
RTreeAddNodePos(Begins at: 28, Ends at:46)
LOC:          |      19 |       |           OK |        19 |
RTreeFlushBuffer(Begins at: 124, Ends at:134)
metrics are OK
RTreeGetNode(Begins at: 68, Ends at:88)
LOC:          |      21 |       |           OK |        21 |
RTreeGetNodePos(Begins at: 49, Ends at:58)
metrics are OK
RTreePutNode(Begins at: 105, Ends at:112)
RTreeReadNode(Begins at: 61, Ends at:65)
RTreeRewriteNode(Begins at: 98, Ends at:102)
RTreeUpdateRect(Begins at: 115, Ends at:122)
RTreeWriteNode(Begins at: 91, Ends at:95)
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/card.c
          Function
RTreeGetLeafMax(Begins at: 45, Ends at:48)
metrics are OK
RTreeGetNodeMax(Begins at: 41, Ends at:44)
metrics are OK
RTreeSetLeafMax(Begins at: 37, Ends at:40)
metrics are OK
RTreeSetNodeMax(Begins at: 33, Ends at:36)
metrics are OK
set_max(Begins at: 25, Ends at:31)
metrics are OK
Clone analysis:
          File :/lib/vector/rtree/card.h
____________________________________________
Threshold grass key metrics values at Tue Jan 04 05:05:27 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
