[GRASS-QA] GRASS QA: mmetz |indexf.c io.c card.h | no clones | 0 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jan 4 05:09:18 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44856
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/rtree/indexf.c
          Class
fstack(Begins at: 30, Ends at:35)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
RTreeInsertRectF(Begins at: 232, Ends at:305)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      74 |     * |      WARNING |        74 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
RTreeDeleteRect2F(Begins at: 313, Ends at:406)
Complexity:   |      13 |     * |      WARNING |        13 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      94 |     * |      WARNING |        94 |
 at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/rtree/io.c
          Function
RTreeFlushBuffer(Begins at: 125, Ends at:135)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
RTreeUpdateRect(Begins at: 115, Ends at:122)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       8 |       |           OK |         8 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/lib/vector/rtree/card.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Tue Jan 04 05:09:15 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
