[GRASS-QA] GRASS QA: mmetz |dig_structs.h | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Tue Jan 4 05:30:52 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44862
ANALYSIS
your changes to files/class/methods/functions :
File :/include/vect/dig_structs.h
Class
Cat_index(Begins at: 227, Ends at:240)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
Class
Coor_info(Begins at: 158, Ends at:162)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Format_info(Begins at: 220, Ends at:224)
Class
Format_info_ogr(Begins at: 168, Ends at:217)
Class
Map_info(Begins at: 386, Ends at:454)
Class
P_area(Begins at: 500, Ends at:520)
Class
P_isle(Begins at: 523, Ends at:539)
Class
P_line(Begins at: 477, Ends at:497)
Class
P_node(Begins at: 457, Ends at:474)
Class
Plus_head(Begins at: 243, Ends at:383)
Class
Port_info(Begins at: 90, Ends at:111)
Class
bound_box(Begins at: 48, Ends at:56)
Class
cat_list(Begins at: 561, Ends at:568)
Class
dblinks(Begins at: 82, Ends at:87)
Class
dig_head(Begins at: 124, Ends at:155)
Class
field_info(Begins at: 71, Ends at:79)
Class
gvfile(Begins at: 59, Ends at:68)
Class
ilist(Begins at: 574, Ends at:579)
Class
line_cats(Begins at: 552, Ends at:558)
Class
line_pnts(Begins at: 542, Ends at:549)
Class
recycle(Begins at: 118, Ends at:121)
Class
site_att(Begins at: 40, Ends at:45)
Class
spatial_index(Begins at: 590, Ends at:594)
Class
varray(Begins at: 582, Ends at:587)
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jan 04 05:30:49 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 228 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
