[GRASS-QA] GRASS QA: mmetz |io.c thin_lines.c | 1 clones | 0
monsters |3 warnings
soccerlab.info at gmail.com
Tue Jan 4 08:47:06 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44866
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.thin/io.c
Function
open_file(Begins at: 85, Ends at:149)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 35 | * | WARNING | 35 |
LOC: | 65 | * | WARNING | 65 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
close_file(Begins at: 151, Ends at:176)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 15 | | OK | 15 |
LOC: | 26 | | OK | 26 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.thin/io.c clones of close_file are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.thin/io.c close_file
File :/raster/r.thin/thin_lines.c
Function
thin_lines(Begins at: 37, Ends at:178)
Complexity: | 19 | * | WARNING | 19 |
CalledNBR: | 32 | * | WARNING | 32 |
LOC: | 142 | * | WARNING | 142 |
encode_neighbours(Begins at: 183, Ends at:209)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 27 | | OK | 27 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jan 04 08:47:00 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 228 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
