[GRASS-QA] GRASS QA: mmetz |index.c index.h io.c | no clones | 0 monsters |5 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jan 4 15:08:51 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44867
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/rtree/index.c
          Function
RTreeNewIndex(Begins at: 34, Ends at:121)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      88 |     * |      WARNING |        88 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/rtree/index.h
          Class
Branch(Begins at: 72, Ends at:76)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Child(Begins at: 65, Ends at:70)
          Class
ListBranch(Begins at: 169, Ends at:174)
          Class
ListFNode(Begins at: 163, Ends at:167)
          Class
ListNode(Begins at: 157, Ends at:161)
          Class
Node(Begins at: 78, Ends at:83)
          Class
NodeBuffer(Begins at: 134, Ends at:139)
          Class
RTree(Begins at: 102, Ends at:155)
          Class
Rect(Begins at: 58, Ends at:61)
          Class
_recycle(Begins at: 126, Ends at:130)
Clone analysis:
          File :/lib/vector/rtree/io.c
          Function
RTreePutNode(Begins at: 121, Ends at:138)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      18 |       |           OK |        18 |
 at least 1 values are close to an outlier please consider revising code!
RTreeAddNodePos(Begins at: 28, Ends at:56)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      29 |       |           OK |        29 |
RTreeFlushBuffer(Begins at: 161, Ends at:173)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
RTreeGetNodePos(Begins at: 59, Ends at:68)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
RTreeGetNode(Begins at: 78, Ends at:104)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      27 |       |           OK |        27 |
RTreeUpdateRect(Begins at: 141, Ends at:158)
ParamNBR:     |       5 |     * |      WARNING |         5 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jan 04 15:08:39 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
