[GRASS-QA] GRASS QA: mmetz |misc.h main.c misc.c network.c ...| no clones | 3 monsters |4 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jan 6 13:17:46 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44899
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.generalize/misc.h
The system don't find class, method and function
 in this file during analysis!
          File :/vector/v.generalize/main.c
          Function
main(Begins at: 43, Ends at:496)
              |          New Metrics           |Old Metrics|
Complexity:   |      56 |   *** |      MONSTER |        56 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     149 |   *** |      MONSTER |       149 |
LOC:          |     454 |   *** |      MONSTER |       454 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.generalize/misc.c
          Function
get_furthest(Begins at: 45, Ends at:74)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
check_topo(Begins at: 227, Ends at:324)
Complexity:   |      20 |     * |      WARNING |        20 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |      98 |     * |      WARNING |        98 |
 at least 4 values are close to an outlier please consider revising code!
parse_filter_options(Begins at: 192, Ends at:223)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      32 |       |           OK |        32 |
Conclusion:   | this function is a  BABY-MONSTER           |
copy_tables_by_cats(Begins at: 79, Ends at:188)
Complexity:   |      17 |     * |      WARNING |        17 |
CalledNBR:    |      34 |     * |      WARNING |        34 |
LOC:          |     110 |     * |      WARNING |       110 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :/vector/v.generalize/network.c
          Function
graph_generalization(Begins at: 71, Ends at:268)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
CalledNBR:    |      80 |   *** |      MONSTER |        80 |
LOC:          |     198 |    ** | BABY-MONSTER |       198 |
Clone analysis:
          File :/vector/v.generalize/operators.h
          File :/vector/v.generalize/displacement.c
          Function
snakes_displacement(Begins at: 32, Ends at:322)
Complexity:   |      40 |   *** |      MONSTER |        40 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      91 |   *** |      MONSTER |        91 |
LOC:          |     291 |   *** |      MONSTER |       291 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Jan 06 13:17:37 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       228 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
