[GRASS-QA] GRASS QA: martinl |vedit.h render.c | no clones | 0
monsters |1 warnings
soccerlab.info at gmail.com
Fri Jan 7 13:03:48 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44903
ANALYSIS
your changes to files/class/methods/functions :
File :/include/vedit.h
Class
robject(Begins at: 50, Ends at:56)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | | | | | | |
Class
robject_list(Begins at: 58, Ends at:62)
Class
rpoint(Begins at: 45, Ends at:48)
Clone analysis:
This file does not contain cloned functions
File :/lib/vector/vedit/render.c
Function
draw_line(Begins at: 145, Ends at:218)
| New Metrics |Old Metrics|
Complexity: | 14 | * | WARNING | 14 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 74 | * | WARNING | 74 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Jan 07 13:03:37 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 227 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
