[GRASS-QA] GRASS QA: martinl |render.c | no clones | 0 monsters |4
warnings
soccerlab.info at gmail.com
Sat Jan 8 12:54:00 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44907
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/vedit/render.c
Function
draw_line_nodes(Begins at: 242, Ends at:279)
| New Metrics |Old Metrics|
Complexity: | 6 | | OK | 6 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 38 | | OK | 38 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
draw_arrow(Begins at: 414, Ends at:435)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 22 | | OK | 22 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
draw_line_dir(Begins at: 334, Ends at:397)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 64 | | OK | 64 |
Vedit_render_map(Begins at: 61, Ends at:141)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 81 | * | WARNING | 81 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Jan 08 12:53:53 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 227 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
