[GRASS-QA] GRASS QA: martinl |cats.c distance.c copy.c render.c
...| no clones | 2 monsters |15 warnings
soccerlab.info at gmail.com
Sat Jan 8 21:52:48 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44910
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/vedit/cats.c
Function
Vedit_modify_cats(Begins at: 31, Ends at:95)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 65 | * | WARNING | 65 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/lib/vector/vedit/distance.c
Function
Vedit_get_min_distance(Begins at: 27, Ends at:77)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 51 | | OK | 51 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
File :/lib/vector/vedit/copy.c
Function
Vedit_copy_lines(Begins at: 27, Ends at:67)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 41 | | OK | 41 |
Clone analysis:
File :/lib/vector/vedit/render.c
Function
Vedit_render_map(Begins at: 61, Ends at:141)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 81 | * | WARNING | 81 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :/lib/vector/vedit/zbulk.c
Function
Vedit_bulk_labeling(Begins at: 33, Ends at:136)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 104 | * | WARNING | 104 |
Clone analysis:
File :/lib/vector/vedit/chtype.c
Function
Vedit_chtype_lines(Begins at: 29, Ends at:83)
ParamNBR: | 2 | | OK | 2 |
LOC: | 55 | | OK | 55 |
Clone analysis:
File :/lib/vector/vedit/vertex.c
Function
Vedit_move_vertex(Begins at: 33, Ends at:177)
Complexity: | 21 | ** | BABY-MONSTER | 21 |
ParamNBR: | 12 | *** | MONSTER | 12 |
LOC: | 145 | * | WARNING | 145 |
Conclusion: | this function is a MONSTER |
Vedit_remove_vertex(Begins at: 282, Ends at:350)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 69 | * | WARNING | 69 |
Vedit_add_vertex(Begins at: 194, Ends at:267)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 74 | * | WARNING | 74 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/lib/vector/vedit/delete.c
Function
Vedit_delete_lines(Begins at: 25, Ends at:47)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 23 | | OK | 23 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
File :/lib/vector/vedit/merge.c
Function
Vedit_merge_lines(Begins at: 47, Ends at:179)
Complexity: | 18 | * | WARNING | 18 |
CalledNBR: | 27 | * | WARNING | 27 |
LOC: | 133 | * | WARNING | 133 |
Clone analysis:
File :/lib/vector/vedit/flip.c
Function
Vedit_flip_lines(Begins at: 25, Ends at:64)
CalledNBR: | 9 | | OK | 9 |
LOC: | 40 | | OK | 40 |
metrics are OK
Clone analysis:
File :/lib/vector/vedit/select.c
Function
Vedit_select_by_query(Begins at: 42, Ends at:124)
Complexity: | 16 | * | WARNING | 16 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 83 | * | WARNING | 83 |
select_by_query(Begins at: 133, Ends at:235)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 23 | * | WARNING | 23 |
LOC: | 103 | * | WARNING | 103 |
Clone analysis:
File :/lib/vector/vedit/snap.c
Function
Vedit_snap_line(Begins at: 99, Ends at:160)
LOC: | 62 | | OK | 62 |
Vedit_snap_lines(Begins at: 175, Ends at:210)
LOC: | 36 | | OK | 36 |
Vedit_snap_point(Begins at: 28, Ends at:82)
Clone analysis:
File :/lib/vector/vedit/move.c
Function
Vedit_move_lines(Begins at: 29, Ends at:95)
ParamNBR: | 9 | *** | MONSTER | 9 |
LOC: | 67 | * | WARNING | 67 |
Clone analysis:
File :/lib/vector/vedit/break.c
Function
Vedit_split_lines(Begins at: 32, Ends at:130)
Complexity: | 13 | * | WARNING | 13 |
LOC: | 99 | * | WARNING | 99 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jan 08 21:52:35 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 227 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
