[GRASS-QA] GRASS QA: mmetz |intersect.c break_polygons.c build.c array.c ...| no clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jan 20 11:28:13 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45105
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/intersect.c
The system don't find class, method and function
 in this file during analysis!
          File :/lib/vector/Vlib/break_polygons.c
          File :/lib/vector/Vlib/build.c
          File :/lib/vector/Vlib/array.c
          File :/lib/vector/Vlib/legal_vname.c
          File :/lib/vector/Vlib/constraint.c
          File :/lib/vector/Vlib/error.c
          File :/lib/vector/Vlib/snap.c
          File :/lib/vector/Vlib/poly.c
          Class
Slink(Begins at: 23, Ends at:27)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
Vect_get_point_in_poly_isl(Begins at: 413, Ends at:536)
              |          New Metrics           |Old Metrics|
Complexity:   |      26 |    ** | BABY-MONSTER |        26 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |     124 |     * |      WARNING |       124 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/Vlib/bridges.c
          File :/lib/vector/Vlib/write_ogr.c
          File :/lib/vector/Vlib/read_nat.c
          File :/lib/vector/Vlib/overlay.c
          File :/lib/vector/Vlib/cindex.c
          File :/lib/vector/Vlib/buffer2.c
          File :/lib/vector/Vlib/header.c
          File :/lib/vector/Vlib/buffer.c
          File :/lib/vector/Vlib/overlap.c
          File :/lib/vector/Vlib/close.c
          File :/lib/vector/Vlib/dgraph.c
          Class
intersection_point(Begins at: 33, Ends at:38)
          Class
seg_intersection(Begins at: 40, Ends at:45)
          Class
seg_intersection_list(Begins at: 47, Ends at:52)
          Class
seg_intersections(Begins at: 54, Ends at:62)
Clone analysis:
          File :/lib/vector/Vlib/break_lines.c
          Function
Vect_break_lines_list(Begins at: 62, Ends at:376)
Complexity:   |      53 |   *** |      MONSTER |        53 |
CalledNBR:    |      71 |   *** |      MONSTER |        71 |
LOC:          |     315 |   *** |      MONSTER |       315 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
          File :/lib/vector/Vlib/rewind_ogr.c
          File :/lib/vector/Vlib/map.c
          File :/lib/vector/Vlib/field.c
          File :/lib/vector/Vlib/hist.c
          File :/lib/vector/Vlib/open.c
          File :/lib/vector/Vlib/read.c
          File :/lib/vector/Vlib/init_head.c
          File :/lib/vector/Vlib/clean_nodes.c
          File :/lib/vector/Vlib/write_nat.c
          File :/lib/vector/Vlib/select.c
          File :/lib/vector/Vlib/open_nat.c
          File :/lib/vector/Vlib/find.c
          File :/lib/vector/Vlib/write.c
          Function
write_dummy(Begins at: 21, Ends at:26)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :/lib/vector/Vlib/close_ogr.c
          File :/lib/vector/Vlib/build_ogr.c
          File :/lib/vector/Vlib/graph.c
          File :/lib/vector/Vlib/dangles.c
          File :/lib/vector/Vlib/line.c
          File :/lib/vector/Vlib/box.c
          File :/lib/vector/Vlib/remove_duplicates.c
          File :/lib/vector/Vlib/close_nat.c
          File :/lib/vector/Vlib/open_ogr.c
          File :/lib/vector/Vlib/merge_lines.c
          File :/lib/vector/Vlib/net.c
          File :/lib/vector/Vlib/type.c
          File :/lib/vector/Vlib/level_two.c
          File :/lib/vector/Vlib/cats.c
          File :/lib/vector/Vlib/list.c
          File :/lib/vector/Vlib/remove_areas.c
          File :/lib/vector/Vlib/dbcolumns.c
          File :/lib/vector/Vlib/read_ogr.c
          File :/lib/vector/Vlib/sindex.c
          File :/lib/vector/Vlib/geos.c
          File :/lib/vector/Vlib/area.c
          File :/lib/vector/Vlib/build_nat.c
          Function
Vect_isle_find_area(Begins at: 131, Ends at:257)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |     127 |     * |      WARNING |       127 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Jan 20 11:28:05 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
