[GRASS-QA] GRASS QA: hamish |eps.c r_plt.c map_info.c do_plt.c | 1
clones | 0 monsters |4 warnings
soccerlab.info at gmail.com
Tue May 3 08:41:48 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 46167
ANALYSIS
your changes to files/class/methods/functions :
File :/ps/ps.map/eps.c
Function
eps_bbox(Begins at: 10, Ends at:40)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | 5 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/ps/ps.map/eps.c clones of eps_bbox are:
/data/project-manager/grass/grassSVN/grass-addons/postscript/ps.output/eps.c eps_bbox
File :/ps/ps.map/r_plt.c
Function
read_eps(Begins at: 109, Ends at:190)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 82 | * | WARNING | 82 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/ps/ps.map/map_info.c
Function
map_info(Begins at: 9, Ends at:113)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 35 | * | WARNING | 35 |
LOC: | 105 | * | WARNING | 105 |
Clone analysis:
File :/ps/ps.map/do_plt.c
Function
do_plt(Begins at: 13, Ends at:183)
Complexity: | 29 | ** | BABY-MONSTER | 29 |
CalledNBR: | 42 | ** | BABY-MONSTER | 42 |
LOC: | 171 | ** | BABY-MONSTER | 171 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue May 03 08:41:42 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 147 | 230 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
