[GRASS-QA] GRASS QA: glynn |mapset_nme.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Tue May 3 15:15:21 EDT 2011
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 46173
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/gis/mapset_nme.c
Function
G_get_list_of_mapsets(Begins at: 53, Ends at:82)
| New Metrics |Old Metrics|
Complexity: | 7 | | OK | 7 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 30 | | OK | 30 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue May 03 15:15:11 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 147 | 230 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
