[GRASS-QA] GRASS QA: hamish |viewshed.cc main.cc grass.cc | no
	clones | 3 monsters |3 warnings
    soccerlab.info at gmail.com
    Fri May  6 04:29:06 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 46200
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.viewshed/viewshed.cc
          Function
print_viewshed_timings(Begins at: 97, Ends at:115)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
viewshed_in_memory(Begins at: 195, Ends at:440)
Complexity:   |      14 |     * |      WARNING |        14 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      70 |   *** |      MONSTER |        70 |
LOC:          |     246 |   *** |      MONSTER |       246 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.viewshed/main.cc
          Function
print_timings_internal(Begins at: 637, Ends at:656)
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      20 |       |           OK |        20 |
print_timings_external_memory(Begins at: 661, Ends at:684)
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
          File :/raster/r.viewshed/grass.cc
          Function
init_event_list(Begins at: 396, Ends at:615)
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |     220 |    ** | BABY-MONSTER |       220 |
init_event_list_in_memory(Begins at: 169, Ends at:381)
Complexity:   |      16 |     * |      WARNING |        16 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      66 |   *** |      MONSTER |        66 |
LOC:          |     213 |    ** | BABY-MONSTER |       213 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri May 06 04:29:03 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
