[GRASS-QA] GRASS QA: mmetz |grass.cc | no clones | 0 monsters |4
warnings
soccerlab.info at gmail.com
Fri May 6 05:55:04 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46201
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.viewshed/grass.cc
Function
save_grid_to_GRASS(Begins at: 625, Ends at:666)
| New Metrics |Old Metrics|
Complexity: | 7 | | OK | 7 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 42 | | OK | 42 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
save_vis_elev_to_GRASS(Begins at: 679, Ends at:778)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 34 | * | WARNING | 34 |
LOC: | 100 | * | WARNING | 100 |
at least 4 values are close to an outlier please consider revising code!
save_io_vis_and_elev_to_GRASS(Begins at: 902, Ends at:1014)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 36 | * | WARNING | 36 |
LOC: | 113 | * | WARNING | 113 |
save_io_visibilitygrid_to_GRASS(Begins at: 825, Ends at:887)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 63 | | OK | 63 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri May 06 05:54:59 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
