[GRASS-QA] GRASS QA: mmetz |raster.c lidar.h zones.c | 3 clones | 1
monsters |2 warnings
soccerlab.info at gmail.com
Sat May 14 09:11:32 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46266
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/lidar/raster.c
Function
P_Regular_Points(Begins at: 190, Ends at:311)
| New Metrics |Old Metrics|
Complexity: | 23 | ** | BABY-MONSTER | 23 |
ParamNBR: | 15 | *** | MONSTER | 15 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 122 | * | WARNING | 122 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/lidar/raster.c clones of P_Regular_Points are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/lidarlib/raster.c P_Regular_Points
File :/lib/lidar/lidar.h
Class
Point(Begins at: 80, Ends at:87)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Reg_dimens(Begins at: 71, Ends at:78)
Class
element(Begins at: 89, Ends at:94)
Clone analysis:
This file does not contain cloned functions
File :/lib/lidar/zones.c
Function
P_Read_Vector_Region_Map(Begins at: 309, Ends at:374)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 66 | * | WARNING | 66 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
P_Read_Raster_Region_Map(Begins at: 376, Ends at:451)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 76 | * | WARNING | 76 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file has 2 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/lidar/zones.c clones of P_Read_Vector_Region_Map are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/lidarlib/zones.c P_Read_Vector_Region_Map
In /data/project-manager/grass/grassSVN/grass/trunk/lib/lidar/zones.c clones of P_Read_Raster_Region_Map are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/lidarlib/zones.c P_Read_Raster_Region_Map
____________________________________________
Threshold grass key metrics values at Sat May 14 09:11:26 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
