[GRASS-QA] GRASS QA: mmetz |resamp.c crosscorr.c bspline.h main.c |
4 clones | 3 monsters |2 warnings
soccerlab.info at gmail.com
Sat May 14 09:16:14 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46267
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.resamp.bspline/resamp.c
Function
P_Read_Raster_Region_masked(Begins at: 25, Ends at:109)
| New Metrics |Old Metrics|
Complexity: | 14 | * | WARNING | 14 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 85 | * | WARNING | 85 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
P_Sparse_Raster_Points(Begins at: 111, Ends at:223)
Complexity: | 17 | * | WARNING | 17 |
ParamNBR: | 15 | *** | MONSTER | 15 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 113 | * | WARNING | 113 |
Conclusion: | this function is a MONSTER |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.bspline/resamp.c clones of P_Sparse_Raster_Points are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/r.resamp.bspline/resamp.c P_Sparse_Raster_Points
File :/raster/r.resamp.bspline/crosscorr.c
Function
swap(Begins at: 108, Ends at:117)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
cross_correlation(Begins at: 120, Ends at:338)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 67 | *** | MONSTER | 67 |
LOC: | 219 | ** | BABY-MONSTER | 219 |
Clone analysis:
This file has 2 potentially cloned functions:
cross_correlation
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.bspline/crosscorr.c clones of swap are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/r.resamp.bspline/crosscorr.c swap
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.bspline/crosscorr.c clones of cross_correlation are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/r.resamp.bspline/crosscorr.c cross_correlation
File :/raster/r.resamp.bspline/bspline.h
Class
Param(Begins at: 29, Ends at:34)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
RasterPoint(Begins at: 36, Ends at:40)
Class
Stats(Begins at: 22, Ends at:27)
Clone analysis:
This file does not contain cloned functions
File :/raster/r.resamp.bspline/main.c
Function
main(Begins at: 31, Ends at:786)
Complexity: | 67 | *** | MONSTER | 67 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 292 | *** | MONSTER | 292 |
LOC: | 756 | *** | MONSTER | 756 |
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.bspline/main.c clones of main are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/r.resamp.bspline/main.c main
____________________________________________
Threshold grass key metrics values at Sat May 14 09:16:09 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
