[GRASS-QA] GRASS QA: mmetz |bspline.h main.c | 1 clones | 1
monsters |0 warnings
soccerlab.info at gmail.com
Sat May 14 09:22:54 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46269
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.surf.bspline/bspline.h
Class
Param(Begins at: 36, Ends at:41)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Stats(Begins at: 29, Ends at:34)
Class
SubZone(Begins at: 43, Ends at:47)
Clone analysis:
This file does not contain cloned functions
File :/vector/v.surf.bspline/main.c
Function
main(Begins at: 37, Ends at:904)
| New Metrics |Old Metrics|
Complexity: | 86 | *** | MONSTER | 86 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 314 | *** | MONSTER | 314 |
LOC: | 868 | *** | MONSTER | 868 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.surf.bspline/main.c clones of main are:
/data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/v.surf.bspline/main.c main
____________________________________________
Threshold grass key metrics values at Sat May 14 09:22:49 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
