[STATSGRASS] R & GRASS inicialization.
Agustin Lobo
alobo at ija.csic.es
Fri Aug 2 06:36:17 EDT 2002
Javier,
No way to skip the R tutorials.
R is a great environment for statistics,
provided that you use it regularly. It is
not for an occasional use.
Learning R basics will take you a short time,
but you really must devote it that time.
Go to http://cran.r-project.org/other-docs.html and
download one or more of the tutorials.
Good luck,
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
On Fri, 2 Aug 2002, andres javier garcia garcia wrote:
> Hello all;
> I've just installed the R interface to GRASS. (I'm new to R), and I'm not
> sure if it is properly installed.
> >From GRASS y type R, and
> >system("g.list rast") shows my raster maps properly.
> Then I've tried to follow the steps indicated in Bivand, (2000). And typed
> >tapply(dem, cover,summary)
> (where dem is a Digital Elevation Model, and cover is a map of different
> clases of vegetal cover)
> and the following message appears:
> Object "cover" not found.
> I've tried the same with different location and mapsets and none works.
> Am I missing something?
> Any previous step is necessary?
> Javier Garcia
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats
