[STATSGRASS] R & GRASS inicialization.
Roger Bivand
Roger.Bivand at nhh.no
Fri Aug 2 06:56:40 EDT 2002
On Fri, 2 Aug 2002, andres javier garcia garcia wrote:
> Hello all;
> I've just installed the R interface to GRASS. (I'm new to R), and I'm not
> sure if it is properly installed.
> From GRASS y type R, and
> >system("g.list rast") shows my raster maps properly.
> Then I've tried to follow the steps indicated in Bivand, (2000). And typed
> >tapply(dem, cover,summary)
> (where dem is a Digital Elevation Model, and cover is a map of different
> clases of vegetal cover)
> and the following message appears:
> Object "cover" not found.
The interface expects you first to collect the grass metadata (current
region):
G <- gmeta()
You can then do
summary(G)
to check that it is OK.
I'm now assuming that you have a number of raster layers in GRASS, among
them dem and cover. I think you did:
dem <- rast.get(G, rlist=c("dem", "cover"), catlabels=c(FALSE, TRUE))
and tried to work on dem. If you do
str(dem)
you will see that it is a list with two members, dem and cover. To get at
the actual data, you need say:
myrasts <- rast.get(G, rlist=c("dem", "cover"), catlabels=c(FALSE, TRUE))
then
tapply(myrasts$dem, myrasts$cover,summary)
NB: for tapply() to work, cover needs to be a "factor" in R terminology.
To get some insight into the meaning of lists, factors, etc in R, Agus'
advice is the best way to go.
> I've tried the same with different location and mapsets and none works.
Please let us know how you get on!
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
and: Department of Geography and Regional Development, University of
Gdansk, al. Mar. J. Pilsudskiego 46, PL-81 378 Gdynia, Poland.
More information about the grass-stats
