[STATSGRASS] Re: GRASS/R interface in ESS
SATO Masaei masaei at affrc.go.jp
Fri Jan 10 18:36:36 EST 2003
Dear Cesare,
Thank you very much for your prompt answer.
Following your advice, I succeeded running R command (library(GRASS)) in ESS.
> start emacs from the existing GRASS session, start R in ESS,
> run the tutorial commands either in the command *R* window or through the
> ESS evaluation mechanisms from a file with .R extensions.
Masaei Sato <masaei at affrc.go.jp>
More information about the grass-stats mailing list
