[STATSGRASS] 3D geostatistics
Edzer J. Pebesma
e.pebesma at geog.uu.nl
Tue May 20 04:56:54 EDT 2003
Javier,
you can "feed" gstat with 3D data in a sites list (haven't checked
this, but it should work); you can then interpolate on a series
of 2D (flat) grids, specifying the height of each grid layer by
set zmap=10.0;
# set height of mask map(s) to 10 when observations are 3-D. [0.0]
or you can interpolate to a 3D grid, defined in a sites list, by using
data(): 'locations';
output: 'sites.out';
where 'locations' and 'sites.out' are the prediction locations and
output predictions sites lists, respectively.
Best regards,
Edzer
More information about the grass-stats
