[STATSGRASS] Re: Building R GRASS interface for MacOS X 10.3 (Panther)
Thomas Adams
tadams1 at cinci.rr.com
Thu Oct 30 20:07:10 EST 2003
Roger,
I do have a fix, thanks to David orme in the UK. Users experiencing the
same problem should go to http://www.gnu.org/software/libiconv/
download libiconv and build from sources. I installed libiconv in my
Fink /sw directory. The R GRASS interface built just fine after doing
this.
Thanks for your help!
Cheers,
Tom
On Oct 30, 2003, at 3:18 AM, Roger Bivand wrote:
> Dear Thomas,
> Unfortunately, I do not have access to Mac hardware/software, and am
> out
> of my depth here. I am forwarding this to the small list within GRASS
> that
> may have some experience - could anyone who has met such problems
> please
> respond on-list so that the answers go into the archive?
> Sorry not to be more direct help, please try out various solutions and
> let
> us know about your progress, I'm sure more people will find your
> experience useful.
> Roger
> On Wed, 29 Oct 2003, Thomas Adams wrote:
>> Roger,
>> I'm trying to build the R GRASS interface for MacOS X 10.3 (Panther).
>> I
>> have built R Version 1.6.2 (2003-01-10) from CRAN sources - although,
>> I thought I was building ver. 1.8, at least that's what the tar file
>> indicated. When I try to use the command:
>> R CMD INSTALL GRASS
>> at the term prompt, I get the following error:
>> * Installing *source* package 'GRASS' ...
>> ** libs
>> gcc -no-cpp-precomp -I/usr/local/lib/R/include -DR_GRASS_INTERFACE
>> -I./include -I/usr/local/include -fno-common -g -O2 -c R_G_init.c
>> -o
>> R_G_init.o
>> dyld: gcc version mismatch for library:
>> /usr/local/lib/libiconv.2.dylib
>> (compatibility version of user: 5.0.0 greater than library's version:
>> 4.0.0)
>> make: *** [R_G_init.o] Trace/BPT trap
>> ERROR: compilation failed for package 'GRASS'
>> Somehow I have a dylib mismatch, but it's unclear to me why it's a
>> problem. Is it because R is compiled with a different library that's
>> older or what? Since I JUST built R and I am now trying to build your
>> R
>> GRASS library, I don't understand how there can be a problem with
>> library incompatibilities.
>> Any suggestions will be helpful.
>> Regards,
>> Tom Adams
> Roger Bivand
> Economic Geography Section, Department of Economics, Norwegian School
> of
> Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
> Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
> e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
