[STATSGRASS] Unable to read GRASS6 data using gstat 2.4.5
Thomas Adams Thomas.Adams at noaa.gov
Sun Aug 21 19:22:57 EDT 2005
List:
I identified the problem with GSTAT not finding the file
'temp_20050101_08' — should have been 'temp_20050801_08'.
However, now I am getting:
data(temp_20050801_08): WARNING: Vector used instead of sites
WARNING: Invalid absolute datetime format
Memory fault
I understand "WARNING: Vector used instead of sites", but I am not sure
of the implication since in GRASS6 sites are vectors. The 2nd message
followed by the Memory Fault is very puzzling.
Regards,
Tom
Thomas Adams wrote:
> List:
> I have point temperature data in GRASS6 (as vectors); I'm using GSTAT
> 2.4.5 which I have compiled with GRASS support (and confirmed with
> gstat -v). From the GRASS6 prompt, when I try to execute:
> gstat gstat.cmd.temps
> I get:
> gstat: read failed on file 'temp_20050101_08'
> where my GSTAT command file (gstat.cmd.temps) is:
> # file: gstat.cmd.temps
> # gstat command file
> data(temp_20050101_08): 'temp_20050101_08', x=1, y=2, v=1;
> variogram(temp_20050101_08): 0.2772 Nug(0) + 0.85 Sph(987521);
> Previously, using GRASS 5.4 and GSTAT, this procedure worked, where
> 'temp_20050101_08' would be my point data. Obviously, I'm missing
> something; any ideas?
> Regards,
> Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
More information about the grass-stats mailing list
