[STATSGRASS] Re: [R-sig-Geo] Unable to read GRASS6 data using gstat 2.4.5
Markus Neteler
neteler at itc.it
Wed Aug 24 10:08:58 EDT 2005
Tom,
I have generated the location and imported the file:
cat temp_20050801_08 | v.in.ascii -z out=temp_20050801_08 x=3 y=2 z=4 col='id varchar(3), y double, x double, elevation double, temperature double' skip=1
# file: gstat.cmd.temps
# gstat command file
data(temp_20050801_08): 'temp_20050801_08', x=1, y=2, v=1;
variogram(temp_20050801_08): 0.2772 Nug(0) + 0.85 Sph(987521);
Running that:
gstat gstat.inp
gstat: Linux version 2.4.5 (17 June 2005)
Copyright (C) 1992, 2004 Edzer J. Pebesma
using Marsaglia's random number generator
data(temp_20050801_08): WARNING: Vector used instead of sites.
WARNING: Illegal TimeStamp string
GRASS site list temp_20050801_08: 0 cat, 3 dim, 1 str, 4 dbl.
Warning: gstat/grass: specify z coordinate if you want to use it
gstat/grass: 117 sites read successfully.
temp_20050801_08 (GRASS site list)
attribute: col[1] [x:] x_1 : [ -91, -78]
n: 117 [y:] y_2 : [ 35, 43]
sample mean: 39.8882 sample std.: 1.84532
[starting interactive mode]
cat temp_20050801_08.est
#gstat Linux 2.4.5 (17 June 2005) [gstat gstat.inp]
#sample semivariogram
#Wed Aug 24 15:45:39 2005
#data(temp_20050801_08): 'temp_20050801_08', x=1, y=2, v=1;
#[1] mean: 39.8882 variance: 3.4052
#cutoff: 5.08806 interval width: 0.339204
#direction: total
# from to n_pairs av_dist semivariogram
0 0.339204 30 0.247674 0.0128483
0.339204 0.678408 89 0.527931 0.0741331
0.678408 1.01761 142 0.847027 0.174927
1.01761 1.35682 175 1.18733 0.294193
No crash so far (I used 6.1 on Linux).
Disussion of the warnings:
-> that's correct since sites are treated as vectors in GRASS 6
I have fixed that (bug in siteslib) in 6.1-CVS and
6.0-CVS (will appear in a potential 6.0.2)
This or similar messages no longer appear.
-> depends on you, the user.
I suggest to update to 6.1-CVS.
A new run with GRASS' siteslib recompiled leads to:
which looks good (to me).
Markus
On Wed, Aug 24, 2005 at 09:37:14AM -0400, Thomas Adams wrote:
> Markus,
> Not the v.in.ascii command, but the columns are:
> ID|latitude|longitude|elevation|temperature
> elevation in feet MSL
> temperature in deg F
> Tom
> Markus Neteler wrote:
> >Tom,
> >[location created]
> >before guessing, please send the v.in.ascii command to me
> >(or tell me what the columns represent)
> >Markus
> >On Tue, Aug 23, 2005 at 08:25:10AM -0400, Thomas Adams wrote:
> >>Markus,
> >>Attached are the files you requested. I have also attached the ascii
> >>vector file as well.
> >>Thanks so much for your help!
> >>Regards,
> >>Tom
> >>>On Mon, Aug 22, 2005 at 04:19:16PM -0400, Thomas Adams wrote:
> >>>>List:
> >>>>I have point temperature data in GRASS6 (as vectors); I'm using GSTAT
> >>>>2.4.5 which I have compiled with GRASS support (and confirmed with
> >>>>gstat -v). I have:
> >>>>data(temp_20050101_08): 'temp_20050101_08', x=1, y=2, v=1;
> >>>>variogram(temp_20050101_08): 0.2772 Nug(0) + 0.85 Sph(987521);
> >>>>From the GRASS6 prompt, when I try to execute:
> >>>>gstat gstat.cmd.temps
> >>>>I get:
> >>>>WARNING: Invalid absolute datetime format
> >>>>Memory fault
> >>>>I understand "WARNING: Vector used instead of sites", but I am not sure
> >>>>of the implication since in GRASS6 sites are vectors. The 2nd message
> >>>>followed by the Memory Fault is very puzzling.
> >>>>Regards,
> >>>>Tom
> >>>Tom,
> >>>could you send the temp_20050101_08 files to me. Since it is
> >>>vector, I would need the mapset/vector/temp_20050101_08/ directory
> >>>and the output of
> >>>g.proj -wef > /tmp/temp_gstat.prj
> >>>to recreate the location here.
> >>>Markus
> >>Thomas E Adams
> >>National Weather Service
> >>Ohio River Forecast Center
> >>1901 South State Route 134
> >>Wilmington, OH 45177
> >>EMAIL: thomas.adams at noaa.gov
> >>VOICE: 937-383-0528
> >>FAX: 937-383-0033
> >>PROJCS["Lambert Conformal
> >>Conic",GEOGCS["wgs84",DATUM["D_WGS_1984",SPHEROID["wgs84",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",60],PARAMETER["standard_parallel_2",30],PARAMETER["latitude_of_origin",39],PARAMETER["central_meridian",-86],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1]]
> >>ALN|38.9|-90.05|545.|64.0
> >>ARR|41.77|-88.47|705.|63.0
> >>BLV|38.55|-89.95|460.|68.0
> >>BMI|40.48|-88.92|880.|69.0
> >>CMI|40.04|-88.27|750.|68.0
> >>CPS|38.57|-90.15|415.|67.0
> >>DEC|39.87|-88.92|670.|66.0
> >>DPA|41.91|-88.24|760.|66.0
> >>LWV|38.76|-87.61|430.|71.0
> >>MDH|37.78|-89.25|410.|64.0
> >>MDW|41.79|-87.75|615.|73.0
> >>MLI|41.45|-90.51|590.|66.0
> >>MTO|39.48|-88.28|720.|67.0
> >>MVN|38.32|-88.87|480.|66.0
> >>MWA|37.75|-89.01|470.|66.0
> >>ORD|41.98|-87.9|665.|72.0
> >>PIA|40.66|-89.69|660.|70.0
> >>PWK|42.11|-87.9|645.|70.0
> >>RFD|42.2|-89.09|735.|64.0
> >>SPI|39.84|-89.68|600.|68.0
> >>SQI|41.75|-89.67|645.|63.0
> >>UGN|42.42|-87.87|730.|70.0
> >>AID|40.1|-85.62|920.|64.0
> >>BAK|39.27|-85.9|655.|70.0
> >>BMG|39.14|-86.61|840.|67.0
> >>EKM|41.72|-86.|780.|70.0
> >>EVV|37.97|-87.57|384.|71.0
> >>EYE|39.83|-86.3|820.|70.0
> >>FWA|41.|-85.2|791.|66.0
> >>GSH|41.52|-85.79|830.|72.0
> >>GYY|41.62|-87.42|590.|70.0
> >>HNB|38.25|-86.95|530.|68.0
> >>HUF|39.45|-87.3|500.|67.0
> >>IND|39.73|-86.28|792.|73.0
> >>LAF|40.42|-86.9|600.|68.0
> >>MIE|40.24|-85.4|935.|67.0
> >>SBN|41.7|-86.32|773.|68.0
> >>VPZ|41.45|-87.01|770.|67.0
> >>BWG|37.|-86.43|535.|70.0
> >>FFT|38.18|-84.9|800.|71.0
> >>JKL|37.6|-83.32|1365.|70.0
> >>LEX|38.03|-84.6|966.|70.0
> >>LNP|36.98|-82.53|2680.|66.0
> >>LOU|38.23|-85.66|545.|72.0
> >>LOZ|37.08|-84.08|1211.|68.0
> >>PAH|37.03|-88.58|325.|65.0
> >>SDF|38.18|-85.73|477.|74.0
> >>ARB|42.22|-83.75|835.|67.0
> >>AZO|42.23|-85.55|870.|71.0
> >>BEH|42.13|-86.42|645.|70.0
> >>BTL|42.3|-85.25|950.|71.0
> >>DET|42.42|-83.02|625.|74.0
> >>DTW|42.23|-83.33|640.|71.0
> >>IRS|41.81|-85.44|925.|64.0
> >>JXN|42.27|-84.47|998.|69.0
> >>OEB|41.93|-85.05|960.|66.0
> >>RMY|42.25|-84.96|940.|70.0
> >>TTF|41.94|-83.43|615.|68.0
> >>YIP|42.24|-83.53|715.|71.0
> >>DKK|42.49|-79.27|690.|71.0
> >>JHW|42.15|-79.27|1720.|63.0
> >>AOH|40.71|-84.03|975.|67.0
> >>BJJ|40.87|-81.88|1135.|66.0
> >>BKL|41.52|-81.68|585.|73.0
> >>CAK|40.92|-81.43|1208.|69.0
> >>CGF|41.57|-81.48|880.|72.0
> >>CLE|41.4|-81.85|777.|69.0
> >>CMH|40.05|-82.88|812.|68.0
> >>CVG|39.07|-84.67|869.|74.0
> >>DAY|39.75|-84.23|1002.|68.0
> >>DFI|41.34|-84.43|705.|65.0
> >>FDY|41.02|-83.67|797.|65.0
> >>ILN|39.42|-83.82|1075.|67.0
> >>LCK|39.82|-82.93|745.|66.0
> >>LHQ|39.76|-82.66|865.|65.0
> >>LUK|39.1|-84.43|480.|68.0
> >>MFD|40.82|-82.52|1295.|68.0
> >>MGY|39.59|-84.22|960.|72.0
> >>MNN|40.62|-83.06|995.|66.0
> >>OSU|40.08|-83.07|900.|69.0
> >>PHD|40.47|-81.42|890.|66.0
> >>TDZ|41.56|-83.48|620.|66.0
> >>TOL|41.6|-83.82|669.|69.0
> >>YNG|41.27|-80.67|1178.|67.0
> >>ZZV|39.95|-81.9|881.|66.0
> >>AGC|40.35|-79.92|1250.|68.0
> >>AOO|40.3|-78.32|1469.|67.0
> >>BFD|41.8|-78.63|2142.|60.0
> >>BTP|40.78|-79.95|1250.|63.0
> >>DUJ|41.18|-78.9|1824.|66.0
> >>ERI|42.08|-80.17|732.|71.0
> >>GKJ|41.63|-80.21|1400.|68.0
> >>JST|40.32|-78.83|2285.|66.0
> >>LBE|40.28|-79.4|1050.|70.0
> >>PIT|40.5|-80.22|1137.|66.0
> >>BNA|36.17|-86.7|590.|72.0
> >>CSV|35.95|-85.08|1810.|70.0
> >>MQY|36.02|-86.52|545.|73.0
> >>TRI|36.48|-82.4|1525.|67.0
> >>TYS|35.82|-83.98|980.|70.0
> >>BCB|37.22|-80.42|2130.|64.0
> >>HLX|36.77|-80.82|2740.|64.0
> >>HSP|37.95|-79.82|3790.|63.0
> >>MKJ|36.9|-81.35|2560.|68.0
> >>PSK|37.13|-80.68|2110.|64.0
> >>ROA|37.32|-79.97|1149.|68.0
> >>SHD|38.27|-78.85|1200.|63.0
> >>VJI|36.68|-82.03|2070.|68.0
> >>BKW|37.78|-81.12|2504.|64.0
> >>BLF|37.3|-81.2|2870.|67.0
> >>CKB|39.29|-80.23|1200.|70.0
> >>CRW|38.35|-81.63|939.|65.0
> >>EKN|38.88|-79.85|1992.|63.0
> >>HLG|40.17|-80.64|1190.|66.0
> >>HTS|38.37|-82.55|827.|67.0
> >>LWB|37.87|-80.4|2303.|61.0
> >>MGW|39.65|-79.92|1240.|67.0
> >>PKB|39.27|-81.57|615.|67.0
> Thomas E Adams
> VOICE: 937-383-0528
> FAX: 937-383-0033
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-stats
