[STATSGRASS] kriging, gstat, GRASS
    Markus Neteler
    neteler at itc.it
    Tue Dec 20 07:20:15 EST 2005
Tom,
as you see, it's lagging behind by 4 days. So an update
seems to be needed.
Markus
On Mon, Dec 19, 2005 at 04:59:42PM -0500, Thomas Adams wrote:
> Markus,
> I was just able to check the GRASS version I am using; it is the CVS
> version dated 2005-08-20.
> --Tom
> Markus Neteler wrote:
> >On Fri, Dec 16, 2005 at 03:15:43PM -0500, Thomas.Adams at noaa.gov wrote:
> >>Markus,
> >>Very likely the GRASS version I'm working with is older than:
> >>"2005-08-24 16:06  markus * lib/sites/sites.c: Brad's updates merged
> >>;crash fixed (gstat related)"
> >>So, should I get the latest GRASS6.1CVS?
> >Yes, please - and you will enjoy tons of other improvements!
> >Markus
> >>Tom
> >>----- Original Message -----
> >>From: Markus Neteler <neteler at itc.it>
> >>Date: Thursday, December 15, 2005 6:05 pm
> >>Subject: Re: [STATSGRASS] kriging, gstat, GRASS
> >>>Thomas,
> >>>On Thu, Dec 15, 2005 at 02:25:33PM -0800, Matthew Perry wrote:
> >>>>Thomas,
> >>>>On 12/15/05, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> >>>>>I'm re-visiting an old issue. Previously, using GRASS 5.3 &
> >>>5.4, I had
> >>>>>no problems with using gstat & GRASS together. Now, I've gone
> >>>to GRASS
> >>>>>6.1 and gstat 2.4.5 (compiled with GRASS support) and I get
> >>>errors. I
> >>>>>apologize that I may have contacted you before about this, but
> >>>I can not
> >>>>>find any old emails. Attached is my gstat input file and a file
> >>>with the
> >>>>>gstat error I get from within my GRASS6.1 session. I'm getting:
> >>>>>WARNING: Vector used instead of sites.
> >>>>I get that warning using the same software versions. However it does
> >>>>not seem to effect the results as I'm able to generate a kriged
> >>>GRASS> raster in spite of the warning.
> >>>This warning is harmless. I just changed the text to
> >>>"Adapted sites library used for vector points (module should be
> >>>updated to GRASS 6 vector library)."
> >>>which is hopefully more explanative. It is intended to the programmer.
> >>>Concerning memory faults: I found this in the ChangeLog
> >>>      * lib/sites/sites.c: Brad's updates merged ;crash fixed (gstat
> >>>        related)
> >>>To replicate the problem I would need a (small) location, the
> >>>gstat script etc, preferably off-list. I can try to check although
> >>>I am pretty busy right now.
> >>>Markus
> >>>Markus Neteler     <neteler itc it>       http://mpa.itc.it
> >>>ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> >>>MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >>>Via Sommarive, 18        -       38050 Povo (Trento), Italy
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL:	thomas.adams at noaa.gov
> VOICE:	937-383-0528
> FAX:	937-383-0033
More information about the grass-stats
