[STATSGRASS] kriging, gstat, GRASS
    Thomas Adams
    Thomas.Adams at noaa.gov
    Mon Dec 19 16:59:42 EST 2005
Markus,
I was just able to check the GRASS version I am using; it is the CVS
version dated 2005-08-20.
--Tom
Markus Neteler wrote:
>On Fri, Dec 16, 2005 at 03:15:43PM -0500, Thomas.Adams at noaa.gov wrote:
>>Markus,
>>Very likely the GRASS version I'm working with is older than:
>>"2005-08-24 16:06  markus * lib/sites/sites.c: Brad's updates merged ;crash fixed (gstat related)"
>>So, should I get the latest GRASS6.1CVS?
>Yes, please - and you will enjoy tons of other improvements!
>Markus
>>Tom
>>----- Original Message -----
>>From: Markus Neteler <neteler at itc.it>
>>Date: Thursday, December 15, 2005 6:05 pm
>>Subject: Re: [STATSGRASS] kriging, gstat, GRASS
>>>Thomas,
>>>On Thu, Dec 15, 2005 at 02:25:33PM -0800, Matthew Perry wrote:
>>>>Thomas,
>>>> On 12/15/05, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>>>>>I'm re-visiting an old issue. Previously, using GRASS 5.3 &
>>>5.4, I had
>>>>>no problems with using gstat & GRASS together. Now, I've gone
>>>to GRASS
>>>>>6.1 and gstat 2.4.5 (compiled with GRASS support) and I get
>>>errors. I
>>>>>apologize that I may have contacted you before about this, but
>>>I can not
>>>>>find any old emails. Attached is my gstat input file and a file
>>>with the
>>>>>gstat error I get from within my GRASS6.1 session. I'm getting:
>>>>>WARNING: Vector used instead of sites.
>>>>I get that warning using the same software versions. However it does
>>>>not seem to effect the results as I'm able to generate a kriged
>>>GRASS> raster in spite of the warning.
>>>This warning is harmless. I just changed the text to
>>>"Adapted sites library used for vector points (module should be
>>>updated to GRASS 6 vector library)."
>>>which is hopefully more explanative. It is intended to the programmer.
>>>Concerning memory faults: I found this in the ChangeLog
>>>         related)
>>>To replicate the problem I would need a (small) location, the
>>>gstat script etc, preferably off-list. I can try to check although
>>>I am pretty busy right now.
>>>Markus
>>>Markus Neteler     <neteler itc it>       http://mpa.itc.it
>>>ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
>>>MPBA - Predictive Models for Biol. & Environ. Data Analysis
>>>Via Sommarive, 18        -       38050 Povo (Trento), Italy
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
More information about the grass-stats
