[STATSGRASS] kriging, gstat, GRASS
Markus Neteler neteler at itc.it
Fri Dec 16 15:19:49 EST 2005
On Fri, Dec 16, 2005 at 03:15:43PM -0500, Thomas.Adams at noaa.gov wrote:
> Markus,
> Very likely the GRASS version I'm working with is older than:
> "2005-08-24 16:06  markus * lib/sites/sites.c: Brad's updates merged ;crash fixed (gstat related)"
> So, should I get the latest GRASS6.1CVS?
Yes, please - and you will enjoy tons of other improvements!
Markus
> Tom
> ----- Original Message -----
> From: Markus Neteler <neteler at itc.it>
> Date: Thursday, December 15, 2005 6:05 pm
> Subject: Re: [STATSGRASS] kriging, gstat, GRASS
> > Thomas,
> > On Thu, Dec 15, 2005 at 02:25:33PM -0800, Matthew Perry wrote:
> > > Thomas,
> > >  On 12/15/05, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> > > > I'm re-visiting an old issue. Previously, using GRASS 5.3 &
> > 5.4, I had
> > > > no problems with using gstat & GRASS together. Now, I've gone
> > to GRASS
> > > > 6.1 and gstat 2.4.5 (compiled with GRASS support) and I get
> > errors. I
> > > > apologize that I may have contacted you before about this, but
> > I can not
> > > > find any old emails. Attached is my gstat input file and a file
> > with the
> > > > gstat error I get from within my GRASS6.1 session. I'm getting:
> > > > WARNING: Vector used instead of sites.
> > > I get that warning using the same software versions. However it does
> > > not seem to effect the results as I'm able to generate a kriged
> > GRASS> raster in spite of the warning.
> > This warning is harmless. I just changed the text to
> > "Adapted sites library used for vector points (module should be
> > updated to GRASS 6 vector library)."
> > which is hopefully more explanative. It is intended to the programmer.
> > Concerning memory faults: I found this in the ChangeLog
> >          related)
> > To replicate the problem I would need a (small) location, the
> > gstat script etc, preferably off-list. I can try to check although
> > I am pretty busy right now.
> > Markus
> > Markus Neteler     <neteler itc it>       http://mpa.itc.it
> > ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-stats mailing list
