[STATSGRASS] kriging, gstat, GRASS
    Thomas.Adams at noaa.gov
    Fri Dec 16 15:15:43 EST 2005
Markus,
Very likely the GRASS version I'm working with is older than:
"2005-08-24 16:06  markus * lib/sites/sites.c: Brad's updates merged ;crash fixed (gstat related)"
So, should I get the latest GRASS6.1CVS?
Tom
----- Original Message -----
Date: Thursday, December 15, 2005 6:05 pm
Subject: Re: [STATSGRASS] kriging, gstat, GRASS
> Thomas,
> On Thu, Dec 15, 2005 at 02:25:33PM -0800, Matthew Perry wrote:
> > Thomas,
> >  On 12/15/05, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> > > I'm re-visiting an old issue. Previously, using GRASS 5.3 &
> 5.4, I had
> > > no problems with using gstat & GRASS together. Now, I've gone
> to GRASS
> > > 6.1 and gstat 2.4.5 (compiled with GRASS support) and I get
> errors. I
> > > apologize that I may have contacted you before about this, but
> I can not
> > > find any old emails. Attached is my gstat input file and a file
> with the
> > > gstat error I get from within my GRASS6.1 session. I'm getting:
> > > WARNING: Vector used instead of sites.
> > I get that warning using the same software versions. However it does
> > not seem to effect the results as I'm able to generate a kriged
> GRASS> raster in spite of the warning.
> This warning is harmless. I just changed the text to
> "Adapted sites library used for vector points (module should be
> updated to GRASS 6 vector library)."
> which is hopefully more explanative. It is intended to the programmer.
> Concerning memory faults: I found this in the ChangeLog
>          related)
> To replicate the problem I would need a (small) location, the
> gstat script etc, preferably off-list. I can try to check although
> I am pretty busy right now.
> Markus
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-stats
