[STATSGRASS] krigged dem lost detail
Markus Neteler neteler at itc.it
Wed Mar 15 04:40:26 EST 2006
Carlos,
I didn't follow this thread in details (although very interesting).
There is cross validation for optimizing tension and smoothing,
did you make use of that (sorry, if already written...)?
I received a script from Jaro to automate the parametrization.
Let me know if you need it (maybe it should go into the Wiki,
so that you/others could document the procedure)
Markus
On Wed, Mar 15, 2006 at 07:16:11PM +1300, Hamish wrote:
> > I am comparing the results we get when re-interpolating a DEM to a
> > higher resolution. I did it with krigging (in R, with gstat) and with
> > RST. In the final result it looks like the krigged DEM has lost
> > detail, while the RST DEM kept those.
> > see it:
> > http://www.igc.usp.br/pessoais/guano/tempo/krigging.jpg
> > http://www.igc.usp.br/pessoais/guano/tempo/rst.jpg
> > I don't know why this happens, since they were interpolated wit the
> > same resolution, based on the same dataset.
> be careful you haven't added detail that isn't really there due to
> spline artifacts. Perhaps resample known DEM at lower resoution and then
> re-interpolate at original resolution to compare which does a better
> job recreating the original DEM?
> r.resamp.rst
> Hamish
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-stats mailing list
