[STATSGRASS] gstat - trend over 3th polinominal
Roger Bivand Roger.Bivand at nhh.no
Sat Nov 11 08:07:40 EST 2006
On Sat, 11 Nov 2006, Edzer J. Pebesma wrote:
> Jarek, we don't know what your "newdata" object is. It is a name of an
> argument, but passed as data; I would expect something like
> predict(g, newdata = meuse.grid)
> I didn't know of that form in formulas, so thanks! Pretty much shorter
> than writing the 4th order polynomial out.
> It might work "in principle" but you may expect increasing inaccuracies
> with higher order trends due to the large difference between say x^4 and
> x. Rescaling the coordinates prior to the analysis (e.g. dividing by
> 1000, going from m to km) might help. poly() doesn't help here, as it
> will rescale differently for meuse and meuse.grid, afaik.
I have tried with:
unroll_trend <- function(np=1, x="x", y="y") {
    ip <- 0
    res <- character()
    if (np > 0) {
        for (i in (0:np)) {
            for (j in (0:(np - i))) {
                if ((i == 0) & (j == 0))
                    next
                else if (i == 0) {
                    ip <- ip + 1
                    res[ip] <- paste("I(", x, "^", j, ")", sep = "")
                } else if (j == 0) {
                    ip <- ip + 1
                    res[ip] <- paste("I(", y, "^", i, ")", sep = "")
                } else {
                    ip <- ip + 1
                    res[ip] <- paste("I(", x, "^", j, "*",
    res
and:
> coefficients(lm(as.formula(paste("zinc ~ ", paste(unroll_trend(1),
collapse="+"))), meuse))
  (Intercept)        I(x^1)        I(y^1)
-2.244418e+04 -4.129057e-01  2.932104e-01
> coefficients(lm(as.formula(paste("zinc ~ ", paste(unroll_trend(2),
  (Intercept)        I(x^1)        I(x^2)        I(y^1)  I(x^1 * y^1)
 7.999712e+06  1.363638e+02  3.618219e-04 -1.223970e+02 -8.059965e-04
       I(y^2)
 4.040368e-04
> coefficients(lm(as.formula(paste("zinc ~ ", paste(unroll_trend(3),
  (Intercept)        I(x^1)        I(x^2)        I(x^3)        I(y^1)
 7.999712e+06  1.363638e+02  3.618219e-04            NA -1.223970e+02
 I(x^1 * y^1)  I(x^2 * y^1)        I(y^2)  I(x^1 * y^2)        I(y^3)
-8.059965e-04            NA  4.040368e-04            NA            NA
but:
> lm(zinc ~ (x+y)^2, meuse)
Call:
lm(formula = zinc ~ (x + y)^2, data = meuse)
Coefficients:
(Intercept)            x            y          x:y
 -2.994e+06    1.608e+01    9.254e+00   -4.974e-05
Roger
> I also wonder what, besides curiosity, the value of a 4-th or higher
> order trend surface might be.
> Edzer
> Jarek Jasiewicz wrote:
> > Hi
> > I found that result of formula:
> > gs=gstat(id="x", formula=zinc~(x+y)^2, data=meuse)
> > pgs=predict(gs, newdata, meuse.grid)
> > is equvalent to:
> > gs=gstat(id="x", formula=zinc~x+y, data=meuse, degree=2)
> > so I tried:
> > gs=gstat(id="x", formula=zinc~(x+y)^4, data=meuse)
> > and it worked!
> > so it is possible to calculate trend over 3th polynominal (now its not
> > a metter for what :))) in that way?
> > regards
> > Jarek
> > statsgrass mailing list
> > statsgrass at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
