[STATSGRASS] gstat - trend over 3th polinominal
Jarek Jasiewicz
jarekj at amu.edu.pl
Sat Nov 11 12:06:04 EST 2006
Edzer J. Pebesma napisał(a):
> Jarek, we don't know what your "newdata" object is. It is a name of an
> argument, but passed as data; I would expect something like
> predict(g, newdata = meuse.grid)
yes, it was an erorr during retyping command of course newdata=meuse.grid
> I didn't know of that form in formulas, so thanks! Pretty much shorter
> than writing the 4th order polynomial out.
I'm not shure if it really works (i.e it is mathematically proper) - I
only point formula which works
> It might work "in principle" but you may expect increasing
> inaccuracies with higher order trends due to the large difference
> between say x^4 and x. Rescaling the coordinates prior to the analysis
> (e.g. dividing by 1000, going from m to km) might help. poly() doesn't
> help here, as it will rescale differently for meuse and meuse.grid,
> afaik.
> I also wonder what, besides curiosity, the value of a 4-th or higher
> order trend surface might be.
> Edzer
> Jarek Jasiewicz wrote:
>> Hi
>> I found that result of formula:
>> gs=gstat(id="x", formula=zinc~(x+y)^2, data=meuse)
>> pgs=predict(gs, newdata, meuse.grid)
>> is equvalent to:
>> gs=gstat(id="x", formula=zinc~x+y, data=meuse, degree=2)
>> so I tried:
>> gs=gstat(id="x", formula=zinc~(x+y)^4, data=meuse)
>> and it worked!
>> so it is possible to calculate trend over 3th polynominal (now its
>> not a metter for what :))) in that way?
>> regards
>> Jarek
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats
