[STATSGRASS] gstat: how to do something like this
Jarosław Jasiewicz jarekj at amu.edu.pl
Mon Nov 20 08:58:13 EST 2006
Edzer J. Pebesma napisał(a):
> Jaroslaw, in R this example is obtained as follows. Assume part.a is a
> field in meuse.grid that tells part a apart from part b:
> require(gstat)
> data(meuse)
> coordinates(meuse) = ~x+y
> data(meuse.grid)
> gridded(meuse.grid) = ~x+y
> # now get the partitioning for meuse:
> meuse$part.a = meuse.grid$part.a[overlay(meuse.grid, meuse)]
> # next do the kriging for each sub-region:
> x1 = krige(log(zinc)~1, meuse[meuse$part.a == 0,],
> meuse.grid[meuse.grid$part.a == 0,], model = vgm(.548, "Sph", 900,
> .0654),
> nmin = 20, nmax = 40, maxdist = 1000)
> # next...
> x2 = krige(log(zinc)~1, meuse[meuse$part.a == 1,],
> meuse.grid[meuse.grid$part.a == 1,], model = vgm(.716, "Sph", 900),
> # combine results...
> x = rbind(as.data.frame(x1), as.data.frame(x2))
> gridded(x) = ~x+y
> spplot(x["var1.pred"], main = "stratified kriging predictions")
> Hth,
> Edzer
> Jarosław Jasiewicz wrote:
>> Hi
>> It means deffernts models for different areasin one grid. Now I can
>> do this with different areas (next merged in grass). As I look on
>> meuse dataset it is probably connected with factor in meuse.grid data
>> frame. I need this to analize different geomorphological units.
>> regards
>> Jarek
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
thanks very much the key is: meuse[meuse$part.a == 0,],
I didn't know how to do that
Jarek
More information about the grass-stats mailing list
