[STATSGRASS] Files not found on the repository
G. Allegri giohappy at gmail.com
Mon Nov 20 21:57:29 EST 2006
I'm installing my packages on Ubuntu Dapper. I've read I have to do the
sequence of commands inside R environment to install all the required
packages:
1 - install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
rS <-"http://r-spatial.sourceforge.net/R"
2 - install.packages(c("spgrass6","spGDAL","spmaptools","spproj"), repos=rS,
dependencies=TRUE)
At this stage R raises an error telling me that it can't find the packages
on the repository... I went to the repository and, as expected, the packages
weren't there. Why? Are the still required or something is changed and
they've been erased from the repository? I found old versions on this site:
http://sourceforge.net/project/showfiles.php?group_id=84357...
3 - install.packages(c("gstat"), dependencies=TRUE)
Is it the right and required sequence at "state of art"?
Thanks in advance,
Giovanni
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20061121/d8b40588/attachment.html
More information about the grass-stats mailing list
