[STATSGRASS] v.variogram
    Roger Bivand
    Roger.Bivand at nhh.no
    Sat Oct  7 09:15:07 EDT 2006
On Sat, 7 Oct 2006, Tomas Lanczos wrote:
> Hello,
> "when running I get the following errormessage:
> v.variogram point=basement_surf layer=1 column=z resolution=70 maxdist=92330
> nlag=15
The script has not been updated to match changes in the spgrass6 package.
west and south in line 117 of the script need to be changed to w and s
from spgrass6 >= 0.3. The list in line 118 will need changing to
data.frame for sp >= 0.9 and R >= 2.4.0. The script would be more robust
if is used the mechanisms described in the GRASS book for argument
passing. It could also condition on package releases.
Apart from that, the script depends on using xpdf to view pdf files, an
you don not have it installed or on your path.
Roger
> Loading required package: sp
> Loading required package: maptools
> Loading required package: foreign
> Loading required package: rgdal
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Error in validObject(.Object) : invalid class "GridTopology" object:
> cellsize has incorrect dimension
> Execution halted
> Done/usr/local/grass-6.3.cvs/scripts/v.variogram: line 135: xpdf: command
> not found"
> What can I do with it?
> Note: If I tried to do kriging by the R I recognized that there is no
> krige.G function for spgrass6.
> Thank for any advice in advance.
> Tomas
> p.s: running Grass 6.3 cvs and R 2.3.0 on Ubuntu 6.0.6,  the databaze is
> PostgreSQL 8.1.3
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
