[STATSGRASS] unfilled matrices with R and gstat in grass 6.2.0beta3
roger at spinn.net
roger at spinn.net
Tue Feb 13 14:45:56 EST 2007
Folks,
This is a user's question, rather than a developer's question.
I have R with the gstat library working with grass6.2.0beta3. On Linux
2.6.13 x86_64 (SuSE 10.0). The software generally works and I can confirm
its results at least approximately against other software. The problem I'm
having is that the resulting map is sometimes not completely filled. I get
calculated values on diagonal lines in the map and the intervening areas are
left unfilled -- they have null values. The same pattern is visible whether
I look at the result from within R or export the result to a grass raster
file.
The pattern is not so simple as a limit to the size of the resulting map. I
have a small set of data (about 60 locations) and need to construct a map of
an area of about 20x30 km, using a grid with spacing of 30mX30m. The
resulting map should have 686736 values, but the the result only contains
171684 non-null values. That is exactly 1/4 of the cells. If I increase
the cell area to 60mX60m so that the grid only contains 171684 cells, then
the result contains 85842 non-null values. That is 1/2 of the cells.
I can construct a map using 16 tiles across the same area and patch them
together to get a completely filled map, but for most purposes that is an
excessive amount of work.
With a different data set with about 250 points and trying to construct a
map over a larger area using a grid with 169576 cells, each 120mX120m I do
get a filled raster map in the result, though the result looks a little odd.
I don't understand what is happening and I've found no mention of this
problem elsewhere. Any ideas?
Roger Miller
More information about the grass-stats
