[STATSGRASS] unfilled matrices with R and gstat in grass
6.2.0beta3
Edzer J. Pebesma
e.pebesma at geo.uu.nl
Tue Feb 13 14:58:00 EST 2007
Roger, we can't look over your shoulder. Please send the script you used
to create the right (but odd) and the wrong results, as complete as
possible.
Thanks,
Edzer
roger at spinn.net wrote:
> Folks,
> This is a user's question, rather than a developer's question.
> I have R with the gstat library working with grass6.2.0beta3. On
> Linux 2.6.13 x86_64 (SuSE 10.0). The software generally works and I
> can confirm its results at least approximately against other
> software. The problem I'm having is that the resulting map is
> sometimes not completely filled. I get calculated values on diagonal
> lines in the map and the intervening areas are left unfilled -- they
> have null values. The same pattern is visible whether I look at the
> result from within R or export the result to a grass raster file.
> The pattern is not so simple as a limit to the size of the resulting
> map. I have a small set of data (about 60 locations) and need to
> construct a map of an area of about 20x30 km, using a grid with
> spacing of 30mX30m. The resulting map should have 686736 values, but
> the the result only contains 171684 non-null values. That is exactly
> 1/4 of the cells. If I increase the cell area to 60mX60m so that the
> grid only contains 171684 cells, then the result contains 85842
> non-null values. That is 1/2 of the cells.
> I can construct a map using 16 tiles across the same area and patch
> them together to get a completely filled map, but for most purposes
> that is an excessive amount of work.
> With a different data set with about 250 points and trying to
> construct a map over a larger area using a grid with 169576 cells,
> each 120mX120m I do get a filled raster map in the result, though the
> result looks a little odd.
> I don't understand what is happening and I've found no mention of this
> problem elsewhere. Any ideas?
> Roger Miller
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats
