[STATSGRASS] WG: Re: WG: Re: WG: Re: gmeta6() returns empty string
Tilmann Steinmetz tilmann.steinmetz at geo.uni-halle.de
Wed Feb 28 11:36:53 EST 2007
hi,
thanks for the hints- but executing the commands from different shells
unfortunately doesn't make any difference.
Speaking of locale settings I realized that this might be the reason and set
out to adjust mine properly from C to de_DE.ISO8859-15 (an itch I've long
planning to scratch) but the result is unchanged --
Is there any way I can go from here without running Grass on, say, Linux?
Tilmann
----- Originalnachricht -----
Von: Roger Bivand <Roger.Bivand at nhh.no>
Datum: Mittwoch, Februar 28, 2007 14:46
Betreff: Re: WG: Re: WG: Re: gmeta6() returns empty string
An: Tilmann Steinmetz <tilmann.steinmetz at geo.uni-halle.de>
> Does this usually correlate with activity on Stromboli?
"g.list rast" rather points to rushmore or even better: bugsites :}
More information about the grass-stats mailing list
