[STATSGRASS] Re: [R-sig-Geo] R (JGR)+ GRASS in QGIS linux ubuntu-feisty
Agustin Lobo Agustin.Lobo at ija.csic.es
Sat Sep 1 03:41:43 EDT 2007
It works fine on linux ubuntu feisty.
If R is run
using the JGR script (from the qgis/grasstools/grass terminal ) and then
spgrass6, I get a nice environment with separate terminals for R (JGR)
and grass. Too bad that, at least for me, the qgis/grasstools terminal
is not working correctly (cannot paste, cannot edit commands, does not
return the prompt after completion of sh scripts...). But this is
another story.
Agus
Roger Bivand escribió:
> On Fri, 31 Aug 2007, Agustin Lobo wrote:
>> Roger,
>>>  On Sun, 26 Aug 2007, Roger Bivand wrote:
>>>  It was a combination of path variables with spaces and the apparent
>>> need
>>>  to call GRASS commands with *.exe extensions from within R in the GRASS
>>>  shell under GRASS Tools (QGIS 0.8.1). From spgrass6-0.4-1,
>>> QGIS/msys/GRASS
>>>  is supported - package revision just submitted to CRAN.
>>>  Roger
>> what does "QGIS/msys/GRASS is supported" mean? Can R be used as a Qgis
>> pluggin? Also for linux?
> No, only that R will work when run in the GRASS Tools -> GRASS shell
> inside QGIS under Windows with the MSYS-built GRASS modules. I do not
> know whether the QGIS Linux version includes a similar GRASS Tools, but
> if so, the shell ought to run R in the normal way. Running
> library(spgrass6) gives access to GRASS.
> Roger
>> Thanks
>> Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
More information about the grass-stats mailing list
