[STATSGRASS] kriging - too long time
Tomas Lanczos
lanczos at t-zones.sk
Sat Sep 1 19:01:46 EDT 2007
I am performing some kriging following the procedure as it is here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/438
My problem is that the kriging proces is very slow, it takes approx. 7
hours. Is the problem a too high resolution, or too much sampling points
(2234)? How can I optimalize the process?
My region setup is the following:
projection: 1 (UTM)
zone: 33
datum: ** unknown (default: WGS84) **
ellipsoid: bessel
north: 5387295.0553002
south: 5288130.42061478
west: 652025.98376024
east: 786301.92841404
nsres: 150.02214022
ewres: 150.02898844
rows: 661
cols: 895
cells: 591595
Many thanks
Tomas
More information about the grass-stats
