[GRASS-stats] counting/sorting lineament lenght according to their azimuth in R
jarekj at amu.edu.pl jarekj at amu.edu.pl
Fri Jul 11 15:32:57 EDT 2008
Yes, to your second problem try to use combination on table() and cut()
function, unfortunatly I cannot send you sample of my code where I use
to the same problem because I'm far from my computer.. (
btw: it is far from your question but for that problem I rather used
readVECT6() and than lm() on imported vector structure instead start and
end x y from grass. It gives better results on irregular or curved
lineament.. the sample code is somewhere on the list...
Jarek
10/7/2008, ""Carlos \"Guâno\" Grohmann"
carlos.grohmann at gmail.com"
<"=?ISO-8859-1?Q?Carlos_\"Gu=E2no\"_Grohmann?="
carlos.grohmann at gmail.com> napisał/a:
>Thanks Jarek, but CircStats only gives me my first need (petals =
>frequency of lineaments). the length of the petals can be adjusted by
>a _constant_ value, not ny the accumulated length.
>tks
>Carlos
>2008/7/10  <jarekj at amu.edu.pl>:
>> try circStats,
>> http://addictedtor.free.fr/graphiques/RGraphGallery.php?graph=97
>> Jarek
>>>Hello all
>>>I was laying around with R packages to do some rose plots. I've found
>>>some, but none gives me what I really want (maybe because they were
>>>made by climatologists and I am a geologist?)
>>>What I want? 2 kinds of rose plots. One where the size of the petals
>>>is proporcional to the frequency (number) of lineaments in a given
>>>direction. Some packages do this, including heR.Misc
>>>(http://www.exposurescience.org). So far, we're good.
>>>Now the second kind of rose plot. In this one, the size of the petal
>>>is proporcional to the accumulated length of the lineaments in that
>>>direction.
>>>The length attribute I get from GRASS, the azimuths, in R (from the
>>>start_x, start_y, end_x, end_y GRASS gives me)
>>>Now, how can I sort/sum the lengths based on the azimuth?
>>>TIA
>>>carlos
>>> Carlos Henrique Grohmann - Guano
>>> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
>>>Linux User #89721 - carlos dot grohmann at gmail dot com
>>>_________________
>>>"Good morning, doctors. I have taken the liberty of removing Windows
>>>95 from my hard drive."
>>>--The winning entry in a "What were HAL's first words" contest judged
>>>by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
>>>Can't stop the signal.
>>>_______________________________________________
>>>grass-stats mailing list
>>>grass-stats at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/grass-stats
>_________________
More information about the grass-stats mailing list
