[GRASS-stats] Re: [GRASS-windows] Re: Build GRASS with MySQL
support enabled
Glynn Clements
glynn at gclements.plus.com
Wed Jul 23 09:34:09 EDT 2008
Marco Pasetti wrote:
> > ok, after some tricks and trials, configure worked; now I'm compiling... I
> > hope it will work :)
> unfortunately it didn't work :(
> I attacched the error messages as a txt file; I hope that someone else could
> help us.
> gcc -I/usr/local/src/grass-6.3.0-test/dist.i686-pc-mingw32/include -I/usr/local/include -g -O2 -I/usr/local/include -I/usr/local/mysql/include -I/usr/local/tcl-tk/include -I/usr/local/tcl-tk/include -DPACKAGE=\"\" -I../../../lib/db/dbmi_driver -I/usr/local/src/grass-6.3.0-test/dist.i686-pc-mingw32/include -o OBJ.i686-pc-mingw32/create_table.o -c create_table.c
> In file included from C:/MSYS/local/mysql/include/mysql.h:72,
> from globals.h:1,
> from create_table.c:15:
> C:/MSYS/local/mysql/include/mysql_com.h:183: error: syntax error before "SOCKET"
I suspect that mysql.h expects you to have included some windows
headers (e.g. <windows.h> or <winsock.h>) beforehand.
Also:
http://dev.mysql.com/doc/refman/5.1/en/windows-client-compiling.html
More information about the grass-stats
