[GRASS-stats] Speedup of readVECT6() with plugin
Markus Neteler
neteler at osgeo.org
Sun Jun 1 16:40:09 EDT 2008
On Sun, Jun 1, 2008 at 8:47 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Sat, 31 May 2008, Markus Neteler wrote:
>> On Sat, May 31, 2008 at 6:35 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>>> On Sat, May 31, 2008 at 5:51 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>>>>> I have to read in Lidar data from GRASS, so speed matters. I have
>>>>>> modified the readVECT6() function to not export to SHAPE but
>>>>>> read in directly via GRASS-GDAL/OGR plugin:
> The SELinux was a red herring, I simply hadn't understood the change in
> plugin technology. The current CVS version works for me on F7 under SELinux
> with the plugin built as described in the wiki.
> Please try the CVS version at:
> cvs -d:pserver:anonymous at r-spatial.cvs.sourceforge.net:/cvsroot/r-spatial login
> cvs -z3 -d:pserver:anonymous at r-spatial.cvs.sourceforge.net:/cvsroot/r-spatial co -P spgrass6
Dear Roger,
thanks for the high speed rewrite of the interface. Downloaded and installed
successfully (I see the new message
"GRASS GIS interface loaded with GRASS version: 6.4.svn"
> or a variant that works. The vector version looks OK,
I have made the test again but cannot observe a speed improvement.
I guess I have to debug it somehow.
> the raster version is
> basic (uses data resolution not window resolution, and only handles one
> raster at a time without categories).
AFAIK the plugin delivers only *original* raster resolution and extent (that's
why r.out.gdal was written in C to replace a former plugin based shell script).
So, unless the plugin is changed here it might not be that useful for raster
data *if* the GRASS behaviour of respecting raster settings during export
should be maintained.
thanks,
Markus
More information about the grass-stats
