[GRASS-stats] GRASS/R interface Vista 64
    Roger Bivand
    Roger.Bivand at nhh.no
    Tue Nov 18 07:22:32 EST 2008
On Mon, 17 Nov 2008, Sam Veloz wrote:
> I am trying to run R from within GRASS. I am running GRASS 6.3.0 with R 2.8.0
> on a Vista 64 platform. I am able to start R within GRASS and load the
> spgrass6 library fine. However when I try:
> G <- gmeta6()
> I get the following error:
> Error in system(paste(paste("g.region", .addexe(), sep = ""), "-g3"),  :
>  g.region not found
Thanks. The most likely cause is that the system is not being identified
as a "windows" system. Could you copy the output from your running R
within GRASS of .sessionInfo() and of Sys.getenv() into an RData file
(save()) and pass it to me off-list? The specific test expects
.Platform$OS.type == "windows", and if it isn't, there may be issues. The
other possibility is that Sys.getenv("OSTYPE") isn't known.
Roger
> If I run g.region -p in GRASS I get:
> projection: 99 (Albers Equal Area)
> zone:       0
> datum:      nad27
> ellipsoid:  clark66
> north:      450300
> south:      -604700
> west:       -373900
> east:       540100
> nsres:      1000
> ewres:      1000
> rows:       1055
> cols:       914
> cells:      964270
> I am new to GRASS but have been working with R for a couple of years. Is
> there something simple I am missing?
> Thanks,
> Sam
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
