[GRASS-stats] GRASS/R interface Vista 64
Sam Veloz
sdveloz at ucdavis.edu
Tue Nov 18 13:35:32 EST 2008
Updating the spgrass6 and rgdal packages fixed the problem.
Thanks,
Sam
Roger Bivand wrote:
> On Mon, 17 Nov 2008, Sam Veloz wrote:
>> I am trying to run R from within GRASS. I am running GRASS 6.3.0 with
>> R 2.8.0 on a Vista 64 platform. I am able to start R within GRASS and
>> load the spgrass6 library fine. However when I try:
>> G <- gmeta6()
>> I get the following error:
>> Error in system(paste(paste("g.region", .addexe(), sep = ""), "-g3"), :
>> g.region not found
> Thanks. The most likely cause is that the system is not being identified
> as a "windows" system. Could you copy the output from your running R
> within GRASS of .sessionInfo() and of Sys.getenv() into an RData file
> (save()) and pass it to me off-list? The specific test expects
> .Platform$OS.type == "windows", and if it isn't, there may be issues.
> The other possibility is that Sys.getenv("OSTYPE") isn't known.
> Roger
>> If I run g.region -p in GRASS I get:
>> projection: 99 (Albers Equal Area)
>> zone: 0
>> datum: nad27
>> ellipsoid: clark66
>> north: 450300
>> south: -604700
>> west: -373900
>> east: 540100
>> nsres: 1000
>> ewres: 1000
>> rows: 1055
>> cols: 914
>> cells: 964270
>> I am new to GRASS but have been working with R for a couple of years.
>> Is there something simple I am missing?
>> Thanks,
>> Sam
Sam Veloz
Postdoctoral Researcher
Department of Environmental Science and Policy
University of California, Davis
More information about the grass-stats
