[GRASS-stats] Re: [R-sig-Geo] writing shapefiles / DBF files when
input data contains NA
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Oct 7 21:15:42 EDT 2008
On Tuesday 07 October 2008, Roger Bivand wrote:
> On Mon, 6 Oct 2008, Dylan Beaudette wrote:
> > Hi,
> > I have noticed that saving data to files that include a DBF, result in
> > bogus data where there were NA. Using the write.dbf() function from
> > the foreign package seems to work a little better, but I still get odd
> > results in numeric columns. Writing to GRASS with the methods in the
> > spgrass6 package results in some thing that looks like this:
> Dylan,
> I'm afraid that there is no good solution for this at all. DBF does not
> seem to have a clear and uniform NA treatment (or even !is.finite()
> treatment). The only work-around is to preprocess the data.frame in the
> output object to insert known NODATA values, and to replace those flags
> manually on the GRASS side. This could possibly be written as a wrapper
> around writeVECT6(). The help page does say:
> "Please note that the OGR drivers used may not handle missing data
> gracefully, and be prepared to have to correct for this manually.
> For example use of the 'readOGR' PostGIS driver directly may
> perform better than moving the data through the DBF driver used in
> this function - or a PostgreSQL driver used directly or through
> ODBC may be a solution. Do not rely on missing values of vector
> data moving smoothly across the interface."
> I did try to look at the SQLite driver on the GRASS side, which might be
> more robust, but did not see how to proceed.
> One possibility is not to recode, but to build an NA mask on the R side,
> and then loop over fields on the GRASS side for the chosen driver
> inserting NAs in the correct rows (whatever the syntax for that might be).
> Would this be db.execute with an insertion of SQL NULL?
> Can we redirect this discussion to the statgrass list, because GRASS
> developers follow that list?
> Best wishes,
> Roger
Sorry for the cross-posting. Wanted to clarify where this thread is
going/went.
Hi Roger--
It looks like the limiting factor in this equation is the code used in
v.out.ogr.
From the GRASS-dev + Frank W's help:
> > Sounds good :)
> > Does anyone know how to fix
> > vector/v.out.ogr/main.c
> > to support NULLs? I see db_set_value_null() in
> > lib/db/dbmi_base/value.c
> > which might be relevant.
> Markus,
> Once you establish which GRASS attributes are NULL, you can ensure they
> are pushed out to OGR as null by just skipping the step that sets them.
> Perhaps that will help a bit.
So, once v.out.ogr is fixed, this should clear up several issues:
1. import of vector data into R via spgrass6 methods
2. better compatibility of vector data exported from GRASS
I still do not know why writeOGR() does not create correct DBF files... it may
be related to the code in v.out.ogr....
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
More information about the grass-stats
