[GRASS-stats] Problems installing spgrass6
Markus Neteler
neteler at osgeo.org
Thu Oct 30 08:35:32 EDT 2008
On Thu, Oct 30, 2008 at 1:28 PM, Edward Tomlinson <e.j.tommo at gmail.com> wrote:
> Dear list,
> I seem to be having a similar problem, cannot install spgrass6 package.
> i have tried R CMD INSTALL and package.install methods. Also tried with
> dependencies = true.
> Still end up with the same error.
> I have gdal 1.5.3 installed seperatly.
> Can anyone give me suggestions?
I searched around and found
http://groups.google.com/group/ggobi/browse_thread/thread/a07061c281fac739?pli=1
"I just experienced (and solved) the same problem (presumably). The
loadNameSpace routine/package/whatever was added as of R 2.5.0, my
guess is that you use a version prior to that. The solution is of
course to install 2.5.0 or later.
(To find out your version, in the R console, type 'version' and look
at minor (contains the last two digits of the version))
https://stat.ethz.ch/pipermail/r-announce/2007/000463.html
R 2.5.0 is released
" o message() has a new argument 'appendLF' to handle messages
with and without newlines. There is a new message class
packageStartupMessage() that can be suppressed separately.
Do you have an older R version installed?
Markus
More information about the grass-stats
