[GRASS-stats] Problems installing spgrass6
Edward Tomlinson e.j.tommo at gmail.com
Thu Oct 30 16:41:35 EDT 2008
Hi Markus,
Thank you for your reply.
I am using R version 2.7.2svn.
Error in fun(...):
    GDAL Error 1: libgrass_I.so cannot open shared object file: No such file
or directory
Error : .onload failed in 'loadnamespace' for 'rgdal'
Could it be an issue with my gdal-grass plugin (i am not sure where the
libgrass_I comes from). I will try updating the plugin.
Thanks,
Ed
2008/10/30 Markus Neteler <neteler at osgeo.org>
> On Thu, Oct 30, 2008 at 1:28 PM, Edward Tomlinson <e.j.tommo at gmail.com>
> wrote:
> > Dear list,
> > I seem to be having a similar problem, cannot install spgrass6 package.
> > i have tried R CMD INSTALL and package.install methods. Also tried with
> > dependencies = true.
> > Still end up with the same error.
> > I have gdal 1.5.3 installed seperatly.
> > Can anyone give me suggestions?
> I searched around and found
> http://groups.google.com/group/ggobi/browse_thread/thread/a07061c281fac739?pli=1
>  "I just experienced (and solved) the same problem (presumably). The
>  loadNameSpace routine/package/whatever was added as of R 2.5.0, my
>  guess is that you use a version prior to that. The solution is of
>  course to install 2.5.0 or later.
>  (To find out your version, in the R console, type 'version' and look
>  at minor (contains the last two digits of the version))
> https://stat.ethz.ch/pipermail/r-announce/2007/000463.html
> R 2.5.0 is released
> "    o  message() has a new argument 'appendLF' to handle messages
>        with and without newlines.  There is a new message class
>        packageStartupMessage() that can be suppressed separately.
> Do you have an older R version installed?
> Markus
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20081031/9497dddf/attachment.html
More information about the grass-stats mailing list
